rustythorn avatar image
rustythorn asked
two multiplus II 48/3000/35-50 120v in parallel but one turned off
looking at will prowse's video we can see that two multiplus II 48/3000/35-50 120v can not only be programmed to run in parallel [split phase] but they can be turned off and back on and will still work fine. i would like to know what happens if only one unit is turned off? will the other unit be able to power 120v items? [assuming those 120v items are wired to the part of the breaker box that the one unit still on is also wired to].
when there is only one unit on will it be able to go into search mode? [since search mode does not work in multi unit systems]
multiplus in parallelsplit phase
