Sander Stolk avatar image
Sander Stolk asked
VRM Instance for a PV inverter by script
I have this plugin that I use since a couple of days. "Script I use" However, when I create a second PV inverter since I have two the script creates a second inverter as instructed but with the same VRM instance ID. The MP-II (and thus the VenusOS) deletes this instance since it's duplicate. The values are also the same with the first PV inverter.
How are the VRM instances handed out in the Victron systems? Is it possible to change the instance ID by hand? Or is the procedure different that the script is telling it to do?
Multiplus-IIVRM
