Good afternoon! It is possible to charge batteries from the sun from the Fronius inverter, and Victron gives an increase in frequency and cuts off this possibility.
How to fix it?
more than 90% of the victron charging does not work.
How to fix it?
What batteries do you have that are running at 59.8v not fully charged? Are you sure the SOC is correct?
Use a shunt for SOC?
there is no shunt here.
AGM battery
last 7 day voltage is normal
73 People are following this question.
