massyn avatar image
massyn asked
Can I add a IP65 charger to a SmartSolar MPPT and Phoenix Inverter setup?
I want to build a little inverter system for home usage (mainly to run a TV and wifi during loadshedding - Yes, I am in South Africa). So I am looking at the SmartSolar MPPT 75/15, Phoenix Inverter 12/500, 160W solar panel and 102Ah deep cycle battery. I want to set it up as per the picture below but was wondering whether I can add the IP65 battery charger to the battery terminals as shown in the image. Will that cause any issues with the battery?
MPPT ControllersPhoenix InverterSolar Panelip65
Alexandra avatar image
Alexandra answered ·
@Massyn
Yes it is. I have exactly the same set up.
Just be sure that the battery can take the amps from both chargers without causing damage.
massyn avatar image
massyn answered ·
Great, thanks @Alexandra. Stupid question but how would I know the amps that the battery can take? My IP65 is a 5A charger and the MPPT 15/75 can do 15A if I am not mistaken, so I would exceed the 102Ah battery's capacity?
Not likely with 20A of charge even if your battery is a lead acid or agm. Most can take that many amps.
Usually the information is in the battery datsheet or on the side of the battery.... Recommended charging amps. Do t forgt to set your voltages.
massyn avatar image massyn commented ·
Great, thanks for the help @Alexandra!
massyn avatar image
massyn answered ·
@Alexandra, one last question. Do I need the inverting remote on-off cable for my application, as shown in the image?
@Massyn
Do you mean this cable?
No you dont need it.
massyn avatar image massyn Alexandra ♦ commented ·
No, I mean this cable.
https://www.victronenergy.com/accessories/inverting-remote-on-off-cable
My understanding is that this cable will allow the MPPT to switch the inverter off if the MPPT detects that the battery voltage is becoming dangerously low.
Alexandra avatar image Alexandra ♦ massyn commented ·
I suppose you could.
To be honest on my 12/800 just used the low battery voltage cut off settings on the inverter. (Have the VE direct BT dongle on it.)
