feggers1316 avatar image
feggers1316 asked
2 x100w panels and a 75/15 blue smart controller
My out shows 10kwh, I've no idea what normal should be? any help
MPPT ControllersSolar Panel
Post a screen shot of wat you are seeing. :)
kevp avatar image kevp commented ·
Not really enough info here. I assume that is the lifetime total? The current output power is measured in Watts on the circular gauge on the app. With 200w of PV you will probably not see much above 150w, unless the temperature is low and the panels are exactly facing the sun. Also the MPPT will only give what is needed (up to max available) so if the battery is fully charged, the watts readout will drop off until a load is applied and the battery voltage drops. (slightly different if you are using the load output function or direct battery connection) Post a picture as suggested below for a better answer.
