The graph is stuck at a 0 to 54 scale.
Troubleshooting already attempted:
- Remove/re-add the graph
- Disable/enable the Has DC System in the CerboGX settings
- Resized the graph
Any other suggestions to fix?
Try make a custom widget for it?
It will show watts though not volts... Or at least mine does. Maybe the size scale you have there is not large enough to show the loads?
31 People are following this question.
