robertilles95 avatar image
robertilles95 asked
Issues with Multiplus and Digital Multi Control
I am running a system that includes a 330ah LiFePo4 Smart Battery and the Multiplus 12|3000|120.
I've been trying to hook up the VE. Bus BMS along with the DMC 200/200A GX and have been running into the same issue every time. I manually configured the multiplus to run according to my battery specs using the mk3 module, managed to get the inverter to light up and accept charge.
When I connect the VE. Bus BMS Mains Detector, the "Low Battery" LED lights up on the face of the inverter (though the battery is fully charged). I Then connect the DMC, the LEDs flash, switch to "Low battery," then the inverter shuts off.
I've tried connecting the DMC with the inverter off. I've turned the system off, waited and tried again and nothing works.
I've even spoken to my local Victron ambassador, and he isn't certain as to what could be causing the issue. Other than possibly a faulty Mains Detector.
If anyone has had the same issue, or has any input, it would be greatly appreciated,
Thanks in advance
BMSmultiplus ve.busfault
4 comments
Can you make a quick sketch how everything is wired up (especially the VE.Bus)?
robertilles95 avatar image robertilles95 Matthias Lange - DE ♦ commented ·
https://www.victronenergy.com/upload/documents/Manual-VE-BUS-BMS-EN-NL-FR-DE-SE-.pdf I can't upload a sketch, but I assure you each component in the system is wired according to their respective manuals.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ robertilles95 commented ·
I gave you some reputation, you should be able to to upload pictures now.
If you can also make some pictures of your wiring.
wiring schematic.JPG This is an old schematic I drew up. I've since upgraded to 4/0 for the battery and inverter connections.
