I have upgraded my MP2 24 3000 to a 5000.
Now I wonder what I can do with this MP2. Do you have any ideas? Or should I just sell it?
This "Multi" in MultiPlus refers to it being multifunctional in that it is a "charger" and an "inverter".
You could thus come up with uses for either a charger or an inverter.
One possible such use would involve connecting the second MultiPlus AC Input to a generator and connecting it to the same DC bus as your 5kVA. Connect it to your GX device with an MK3 USB and then use it as a battery charger - and you can tune the VE.Configure settings accordingly so the AC Input accepts the generator.
You then end up with a site like this (pretend the Quattro is a MultiPlus-II 5kVA). The MP2 3kVA will show as charging when the generator is running and you can remote start the generator based on SoC from the GX:
Thanks for your command, but a generator is unfortunately not an option since fuel prices are extremely high in my area.
78 People are following this question.
