george07 avatar image
george07 asked
unexpected PV-inverter display within VRM-portal
in a 3-phase Multiplus II (48V, 5000) there is a SMA inverter connected to Output-1. That works like expected. Now I switched on the TCP- and UDP-Server in the SMA inverter. The actual PV-data is now displayed within the VRM-Portal, but on the wrong side (Input-1). In Device panal the VRM-portal shows inverter is connected to Input-1! That gives unexpected sumary data within the VRM portal. And yes, the SMA-inverter is configuered as connected to Output-1 in the system configurator.
What can I do?
vrm advanced
