For wifi coverage reasons, I'd like to locate my Cerbo about 15m away from the Multiplus. Any reason why not?
It depends on which ports you are using on the Cerbo GX
every protocol has it's own specified distance.
Keep in mind that the specified lengths are with the right cabling. Every protocol has a different cable but can have the same connector.
For example: a rj45 cat 6 cable is internally different then a rj45 CAN cable. (CAN cable has 2 individually shielded pairs of different sections, the data wires are thin, the power wires are thicker)
Most of the communication problems on this forum are with bad cabling, so test well before hand!
79 People are following this question.
