lele avatar image
lele asked
Multiplus charger only mode maximum watt transiting through ?
Hi everyone,
I have a small multiplus 500, i was wondering if it is possible to power up a 1000watt tools while charging in charger only mode with the citypower.
I can easily understand why i can’t connect the object without city power but will the multiplus be able to handle the use of the 1000 watt tools if it is just transiting through ac in / ac out ?
Thanks !!
Multiplus-IImultiplus ve.busacfeed-in limit
nickdb avatar image
nickdb answered ·
This is all nicely documented in the product spec sheet. The transfer switch is 16A, so that is what it can pass through.
"When the switch is switched to “charger only”, only the battery charger of the Multi will operate (if mains voltage is present). In this mode input also is switched through to the “AC out” terminal."
