nesswill avatar image
nesswill asked
Smart shunt temp coefficient
I have a 1300ah 48v setup of AGM batteries and as it gets cold in the UK should I change the temp coefficient setting in the smart shunt from 0 to something else, can anyone advise please?
Thanks Dave.
SmartShunt
JohnC avatar image
JohnC answered ·
Hi @nesswill
This is only applicable if you have the accessory temp sensor, AND you're not using either of the Aux port Voltage functions. If that applies, then this from the manual..
You could try it. But many of us would probably find more usefulness in one of the Voltage functions.
Thanks for the correction, just learnt something.
nesswill avatar image nesswill commented ·
Thanks, yes everything else is setup thanks to advice from some very kind and helpful people here like yourself.
Regards, Dave.
kevgermany answered ·
Smart shunt doesn't have a temperature setting.
Chargers like the multiplus do.
