markmoto avatar image
markmoto asked
SmartShunt Amps out & amps in not match ?
Smartshunt wont show correct amps out.
When Victron AGM battery fully charged I usually have 4-6 amps left in "Consumed Ah" just before it resets to 100%
On smartshunt I adjusted Charge efficiency factor to 99% without any significant results.
What else can I do to reduce the difference please?
Using Orion Smart TR 12/12-30 to charge battery.
@markmoto
SmartShunt
Can you make a screenshot of the settings?
markmoto avatar image markmoto Matthias Lange - DE ♦ commented ·
See screen shot of smartshunt battery settings. I have increase time to 10 min so I can take screenshot before It resets to 100%. Also Orion charger set to victron default agm profile with float of 13.8
markmoto answered ·
I found the problem, on first install needs "Zero current calibration" even if it showing 0 in "Current".
markmoto answered ·
Here another screenshot of interface while battery fully charged and in float mode.
