hbo-electrical-contractors avatar image
hbo-electrical-contractors asked
Programmable Relay User Interface on Touch Screen
Hi there.
We have set up two assistants in VeConfig to control the programmable relay for AC2 Output.
Is there a user interface available to change the set points of the Programmable Relay assistant directly from the Touch Screen?
Because to change the settings at the moment one needs to use Remote Config to do so.
Thank you in advance!
Renier
MultiPlus Quattro Inverter Chargercerbo gxtouchscreen
wkirby avatar image
wkirby answered ·
Assitant configuration or setting cannot be accessed via the touch screen.
You need to use VE.Configure to configure assistants.
