waninae39 avatar image
waninae39 asked
smart shunt; no longer connects to bmv712-how to set lion battery pams?
i have two shunts an older 500a shunt and a newer 1000a smart shunt.
the older shunt allows me to set lion charge parms from the bmv712 screen.
the newer smart shunt does not connect to the bmv712 and only connects to the cerbo gx port
the cerbo sees the smart shunt but i cant find how to change battery charge setting on the colour screen or the VRM portal
anyone else have this setup or can let me know where to go or how to di it?
cerbo gxBMV Battery MonitorLithium BatterySmartShunt
klandos avatar image
klandos answered ·
Smart shunt can be configured with Victron connect / bluetooth
waninae39 answered ·
pls provide more details . the Bluetooth setting is only for setting the password.
i need to setup the charging for the lion batteries, there are no details in the smart shunt document
SOLVED
i had to use my phone VRM app
then connect via BT to the smart shunt, them i was able to set all the parms (parameters) now its charging fine
