duswami avatar image
duswami asked
Can the Smart Shunt 500 satisfy ESS requirements.
Working on setting up an ESS system and currently have a Smart Shunt 500A ve Direct into the Cerbo. Generally speaking, will this satisfy the battery monitoring requirements for most ESS applications or do I need to upgrade?
System:
Multi II 48v 3000/35 120v
150/45 MPPT
Smart Shunt 500A
Lynxh Dist
Cerbo GX
200Ah AGM bats
1.5 kw Solar
cerbo gxESSBMV Battery MonitorSmartShunt
mindaugas avatar image
mindaugas answered ·
I am using it for my ESS and it works. Time to time I need manually readjust SmartShunt based on BMS SOC. What I also found as must is current transformer used on grid input phase wire for ESS to work. I am not feeding back to grid.
duswami avatar image duswami commented ·
Thanks @WKirby @Mindaugas . I didn't want to get another battery monitor, and yes I'm under 500A. I have an EM24 AV6 I will be using as a CT.
wkirby avatar image
wkirby answered ·
You can use the 500A SmartShunt in an ESS system, provided your DC current is less than 500A of course.
