beattiemark avatar image
beattiemark asked
VE.Bus System [275] - Low battery: Alarm
I am just installing a Multiplus-II GX with 48v LiFePo4 batteries. The batteries have CAN BMS which I have plugged into the CAN Bus socket on the Multiplus-II.
I get the following alarm - VE.Bus System [275] - Low battery: Alarm. The display on the Multiplus-II shows the battery voltage as 49.9v. Can anyone help with this please ? Thanks.
battery charginglow battery warning
Paul B avatar image Paul B commented ·
Hi, Not enough information . ie what canbus bms is being used has it been setup correctly
please send screen shots of all the setup you have done
VictronConnect VE.Bus charging manual
