fabian avatar image
Single VE.bus port limitations with MultiPlus 12/1200/50
The MultiPlus 12/1200/50 “non- compact” (PMP122120000) has one single VE.Bus port.
Is it possible to connect a VE.Bus BMS and a Venus device to this MultiPlus model at the same time or is this only possible with one of the other MultiPlus models (with two VE.Bus ports)?
Thank you!
MultiPlus Quattro Inverter ChargerCCGX Color ControlVE.Busve.bus bms
Hi, you can connect both. Use the dual ports on the Venus-device for that.
Margreet Leeftink (Victron Energy Staff) avatar image
Margreet Leeftink (Victron Energy Staff) answered ·
Hello, It is also possible if you use a RJ45 splitter on the inverter Rj45 port.
