My Setup is as follows with 3 Multiplus II - 8000 for 400v 3Phase:
![xmgtop5.jpg](/storage/attachments/38267-xmgtop5.jpg)
The PV Inverter is on the Net side then the Cable goes into the 3 Multiplus Input and then Output 2 goes into the house.
Now my question: In the VRM Portal it looks like this:
if i enable the switch AC-Output in ESS it looks like this:
Why is critical loads in plus and so high when the Grid is negative? Why is load at 0? Is it because of the used Meter ET340? I read something about it giving wrong data in a single phase system?
Thanks!
Cheers
C.
