d-angles avatar image
d-angles asked
LiTech Power LiFePo4
Dear All,
Currently I am busy with setting up an Victron ESS system based on a multiplus II and Cerbo CX module. I want to add to this system a third party battery set. Does anyone has experience with the Litech power LiFePo4 48V 100Ah Powerwall Energy Storage system (LPPW48V100AH16S1PF001) (www.litechpower.com) ??
see also the following link: LiTech Power LiFePo4 48V PowerWall Energy Storage System - LiTech Power Co.,Ltd
I was wondering if someone has experience with these battery's or maybe already is using these? Particularly if the communication between the Litech BMS with the victron system is functioning fine.
I want to connect three of these 48V/100Ah in parallel.
Many thanks in advance for replying,
Dirk
Lithium BatteryBMScommunication protocol
Looks very generic, compatibility might vary.
LiTech battery pack.
noori-henry avatar image
noori-henry answered ·
We tried their samples, worked flawlessly with victron 5kw inverter plus the Cerbo.
