puigverd avatar image
puigverd asked
Blackouts in off grid installation. With grid inversors.
Good morning
We have problems with blackouts in a off grid installation. We have thisproblema in two systems and in both of them we have installed BYD LVS batteries.
This system it has a Victron Multiplus 10000/140, 4 BYD LVS batteries, a grid inversor Kostal Piko MP 5kw and a Victron color control.
With the batteries at 100% of SOC, after 2 hours aprox the system make a blackout. We don’t know the cause, we try go down the bulk voltatge at 55,4V because we have a hight voltatge warnings.
We have charging the AC current assistent and the PV iverter assistent. We attached the frecuencies configuration.
You know the cause that can cause this blackouts? We have the same problema with another installation, the differences is that the grid inversors is a Sunny boy 6.0 and also there are 6 batteries and a Victron MPPT 450/100.
Also, attached the grafics where it can see the blackouts.
Thanks!!!!
offgridBYD
lifeingalicia avatar image lifeingalicia commented ·
No idea why you have 2 hybrids but I noticed the fail seems to be at SOC 100 this may indicate that the multio cant control the PIKO - Check that he pico actually can be regulated down at the given frequencies. It looks like BMS is shutting down.
Hi @Puigverd,
This might be occurring because there is a cell or two that is a little imbalanced.
There are some instructions here in the BYD compatibility guide for how to reduce the DVCC target voltage to potentially reduce the overshoot. Try that and see if it resolves the issue.
12. High voltage warning or alarm shown on battery status
In the long run, the battery cells should rebalance and it should be possible to disable this again to enable a full charge.
