Hello everybody
I have already a Fronius 4.6 and want to put more panels at home and a DIY -LiFePo battery
Will this work? can be configured and monitored correctly with the CerboGX?
Want to control batteries charging + power feed to the grid.
Hello everybody
Hi
Yes that will work OK i have a very similar system running that way.
Regards
Rob D
NZ
Thank you Rob,
do you have a picture where I can see how does Victron monitors and represents the diagram in a screen?
can you regulate how much do you feed into the grid and which sources you use to charge the battery?
Thank you
Hi Yes you can.
57 People are following this question.
