matthew-burnett avatar image
matthew-burnett asked
Multiple inverters on one GX and battery
I am looking at installing a system for 5 property's on the some site but have separate energy meters but are owned by the same company, they have panels already installed, they are wanting one battery back and backup genset, can you put one multiplus 48v 5kva for 4 of the properties and one quattro 10kva for the main house on one battery bank with one GX device. Thanks in advance
MultiPlus Quattro Inverter Chargerbatterygx devicemultiple inverters
Alexandra avatar image
Alexandra answered ·
@Matthew Burnett
No. One GX for every inverter since you want each to be managed separately. Or with different sized inverters mixed.
This will also mean by default one battery bank for each inverter since they need to be managed separately.
Either that or you do a big 30kVa system with one bank feeding each DB. And a battery bank to match.
matthew-burnett avatar image matthew-burnett commented ·
@alexandra
Ok thanks, but could you put all 5 as the same size and type but feeding separate loads
