miya avatar image
miya asked
Lithium and Lynx Smart BMS - Strange V behaviour
Hi All
New system -
  • 4x Smart Lithium 330Ah
  • Paralleled to Lynx Distributor
  • Connected to Lynx Smart BMS
  • With Lynx Distributor on loads side of BMS
  • Multiplus II connected to Distributor
  • Cerbo GX and Touch 70 powered off Smart BMS Aux
  • No other loads or charging sources attached
  • Brand new system - being commissioned
Batteries fully charged and balanced - multiple times. When the batteries are charging and discharging - I am seeing a strange behaviour in the voltage - which I wouldn't expect.
Discharging -
I would expect the V to drop quickly between 100% to 95% SOC and then remain fairly constant under a stable load until about 30% SOC - and then drop off quickly. I have only taken the batteries down to 50% SOC - but I am seeing the V drop, when under constant load to early -
  • with a constant load of about 5A the V sits at about 13.29v until 68% SOC
  • at 68% SOC the V starts to drop
  • it stops dropping at about 62% SOC and the settles at 13.13v
  • its then stays at this same V all the way to 50% SOC (I have not gone deeper yet)
Charging -
I see the opposite happening - the V rises quick between 62% and 68% SOC.
My previous system (3x 200Ah Lithium and VE.Bus BMS) - never had this behaviour.
Am I worrying about nothing ?
Thanks all, Tim.
Lithium BatteryBMSlynx distributor
@Miya
Yes I think so. We're talking of 150mV voltage drop or increase in a relatively short time frame. Nothing to worry about and quite normal. I see the same on my system.
Discharging - voltage drop of like 130mV at around 62%
miya avatar image miya commented ·
Great - Many thanks Stefanie - and as always - thanks for your help.
