I have 8 tanks on my boat which are all resistive. The CerboGX can take 4. How can I add 4 more? Is there a way to convert a resistive sensor to be voltage or current based so the Tank 140 will support it?
@crholliday , I think you should purchase a CerboGX tank level 140 module which can handle Voltage based or 20mA. current loop sensors. It connects to the USB port on the CerboGX.
Sorry… I should have read the question more carefully….. Victron do produce a VE.Can resistive tank adapter but they are expensive. You can have up to 16 of these on the one network. Quite expensive though.
38 People are following this question.
