zeron avatar image
zeron asked
Connecting Multiplus-II, Cerbo GX, Pylontech batteries and a Fronius Primo
While trying to connect everything I realise I made a mistake on the first cable, so I'm trying to make sure I got everything right before returning the wrong cable and buying the right ones.
Cerbo-GX <--> Pylontech US2000C : I need a "VE.Can to CAN-bus BMS type A Cable 1.8m" from "BMS.Can" port to "A/CAN" port right?
Multiplus-II 5000 <--> Cerbo GX : I need a RJ-45 UTP cable right from MP's "VE.Bus" port to Cerbo's "VE.Can" port right ? Is this just a standard Ethernet cable?
Fronius Primo <--> Cerbo GX : I just need both device connected to the same network through their LAN ports? Is it enough if both devices are on the same WiFi network?
Thanks for the help !
connection issuebattery connectionrj45 cable
seb71 avatar image
seb71 answered ·
Yes, it's a standard UTP/LAN/RJ45 cable.
But in Cerbo you plug it in a VE.Bus port, not in a VE.Can port.
zeron avatar image zeron commented ·
That makes sense, thanks
