bradg avatar image
bradg asked
“No Tanks Found” on Cerbo GX
I recently added Kus tank level senders to my system and connected them to my Cerbo GX’s analog inputs. They were functioning fine for a couple of weeks. Then today, I emptied my grey tank and filled fresh water tank and later noticed the level readings were “stuck” at pre-drain/fill level. I rebooted the system and then instead of having correct or incorrect levels, I got a “No Tanks Found” message instead. I checked my electrical connections and all is fine. I rebooted again for good measure and got the same message. I’m running firmware v2.61. Anyone else have this issue and have a solution? Thanks in advance.
Brad
cerbo gxtank monitor
JohnC avatar image
JohnC answered ·
Hi @BradG
2.61 fw is quite old now, the latest release is 2.87. Try that.
