nellyccc3 avatar image
nellyccc3 asked
New ESS setup for Easy Solar 2
Could someone please answer the following. I am currently setting up the above and have taken the following steps
Installed Easy Solar 2 48/5000
Wired AC In from main consumer unit on 32Amp MCB via a 63Amp double pole isolator using 4mm cable
Connected victron current sensor to mains side of above isolator (not sure if it should be placed before consumer unit????)
Wired AC 1 back to main consumer on 50Amp MCB via a 63Amp double pole isolator using 6mm cable
Connected network cable to the internet
Created login via VRM portal
Updated all components to latest firmware
I am wanting to load the ESS assistant so that I don't feed back to the grid as there is currently no financial incentive to do so.
I have 10 X Canadian Solar 455w panels in place ready to connect to the MPPT
I have 2 X Pylontech US5000 that arrive next month that eventually want to be able to fill them up with excess solar.
My question is, what is the best way of setting the system up so that I can use the current solar without feeding back to the grid whilst my batteries arrive in 6 weeks time.
Any help would be greatly appreciated
ESSEasySolar All-in-Onegrid
marekp avatar image
marekp answered ·
@nellyccc3
Not much you can do without battery.
I suggest reading and listening to all you can find on Victron Professional site.
nellyccc3 answered ·
Thanks for your answer, would I be able to connect the solar at least?
@nellyccc3
You can do all wiring but MPPT will not work without battery same as ES-II.
If you have grid-tie inverter, it can be used without battery.
You can temporally use four 12V LA batteries and if you set your ESS to "keep the batteries charged" they can even be the cheap starter type. This way the MPPT will work for your loads.
Many thanks for your answer, that makes perfect sense
