ryan-mack avatar image
ryan-mack asked
Tracking Solar Amp Current Output
Hello All,
I have an MPPT 100/20 48V charge controller connected to a small battery. I would like to track the available Amp output from the panels. The display notates the Voltage, but does not display Amps unless there is flow from panels into the battery (Perhaps I'm misreading this?). Either way, is this possible? I've tried under trends but that also doesn't seem to solve the display.
I've looked for other solutions for active data recording of the Amp output - I'm open to suggestions because I haven't found one. Would ideally like to see both Voltage and Amp current recorded together.
Thanks!
MPPT ControllersSolar Panelinput currentamps
MPPT Product Page
MPPT Error codes
