charlie-d avatar image
charlie-d asked
3 phase Multiplus II error lights
I have a 3 phase 3KVA Multiplus II setup that has gone into error but the lights are confusing. Line 1 and 2 have the bulk and float lights flashing together about every second, no other lights on. Line 3 has the absorption and float lights flashing about every second with no other lights on.
This is the CCGX showing an overload and over temperature alarm, although not showing on any of the inverters. Have tried to reset the inverters which have no load on them but it just comes back to same error without starting normally. Nothing in Victron toolkit light explanation helps here.
The system is remote but offline so I do not have access to it.
Any help would be appreciated
Multiplus-IIerror
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
