mik avatar image
mik asked
Smart BMS CL not charging
We have the same issue with multiple Smart BMS CL: They are not letting significant charge to the Lithium batteries even though the alternator is running at high speeds.
Screenshot attached - we have a 100A alternator, engine running at 2000rpm, the device shows 5% load and no significant current flows towards the battery. We had the same / similar issues on multiple boats and caravans.
whatsapp-image-2022-06-01-at-174313.jpegAny idea what the reason could be? It can not really be linked to the batteries - we have tried bridging the M8 connectors with a BMS cable, still the same behavior..
battery chargingLithium BatteryBMSalternator
james-ward avatar image
james-ward answered ·
Did you find a solution?
Ceryll Beckers avatar image
Ceryll Beckers answered ·
Are the bms connections bridged because a lynx bms is used?
in this case 56k resistors must be included in the cable.
