Frank avatar image
Frank asked
Lithium battery voltage below < 12 volt @ 41% SOC and BMS shutdown @ 39% SOC / 11.2 volt
I have a system with 2 x 330AH smart lithium batteries = 8 kW
12 volt system
I thought i could discharge to 5% SOC, but at 40% the voltage drops below 11.2 Volt and i have a BMS shutdown. With no big loads connected at the moment.
Charging from 40% to 100% was done in 2 hours @ 195 amps = 4.6 Kwh
Which means the capacity of my victron smart lithium batteries is comparable to lead acid batteries.
Is this a manufacturing problem? or could it have anything to do with my parameters.
The batteries where fully charged a couple days ago and both balanced.
Decreasing the BMS shut down voltage does not look to make any difference, with this rapidly declining voltage.
From 45% SOC the batteries voltage is rapidly declining, so it's looks very empty.
So it looks like i got batteries of 200 AH instead of 330AH.
4600/0.95/2/12=201AH
Below some graphs, the shutdown was @ 05:51
The characteristic of this new batterie looks in no comparison to the graph from the manual.
2022022401 - Bootschappen-1.pdf
voltagebattery system voltage
5 comments
@Frank
Please provide us with more information about your system.
What is the BMS? How do you measure voltage and calculate SoC? What are your permanent loads etc.?
Frank avatar image Frank Stefanie (Victron Energy Staff) ♦♦ commented ·
@Stefanie I have uploaded the single line installation drawing. I have a VE.bus BMS and a BMV-712, Quattro 12/5000/220, Cerbo GX, all just installed together.
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ Frank commented ·
Can you please also add your BMV settings?
@Stefanie added from victron connect
@Stefanie my permanent loads are two refrigerators, approx 110 Watts AC en 60 Watt DC, what was also running during the night before the voltage drop and shutdown.
@Frank
Looking at your battery monitor settings, it may well be that the battery monitor synced to 100% too early the last time the batteries were fully charged.
Try raising the charged voltage (Geladen spanning) to 14.0V. This will make the battery monitor sync to 100% when the battery can be considered almost full.
Please let us know if it works for you.
Frank avatar image Frank commented ·
@Stefanie oke i will try this
Also the actual battery charging voltages (in the MPPTs and in the inverter) are most likelly set too low.
