I have a very specific battery system, nominal it is 48V, but at its lowest SoC it is 31V. Will the multiplus be able to start charging when the battery is at this point or will it go into error?
The Multi will stop discharging at 37,2V (that is the lowest value you can set) but should be able to start charging with only 31V.
38 People are following this question.
