dylan-hyslop avatar image
dylan-hyslop asked
How to configure VRM when we have a single MP2 on a 3 phase system
Good day,
I have a 3 phase mains power, on of the phases we have run through a MP2 in order to backup those plugs and lights.
Now I have an issue on VRM where it is getting confused as to which phase it is on? See image below.
1653974386586.pngIts drawing nothing from the battery however grid is less than the AC Loads.
Is there a setting in the MP2 to tell it which phase it is on?
Multiplus-IIVRM3 phase
der-hannes avatar image
der-hannes answered ·
As far as I know there is no way to tell the MP2 what phase it is at. At least not if you only use one. However, a single MP2 should always be connected to phase 1!
And you could take a look and see if you have activated the "balancing over all phases" in the settings.
Best regards
Hannes
