jordanb avatar image
jordanb asked
Can CerboGX gen start/stop relay work with SolidSwitch104?
On a boat, can I wire the gen start/stop relay on the CerboGX to a SolidSwitch104, which will be connected to the ignition wire on my Balmar voltage regulator?
The way I understand it, this is possible by connecting a 12v source to COM and then run a wire from NO to the SolidSwitch. And so I program the gen start/stop relay to go on at 30 SOC% and off at 75 SOC%, for example, should close the circuit, activating the SolidSwitch (and therefore closing the circuit on the ignition wire). When SOC% reaches the set value, the relay returns to NO state (opens again) and this de-activates the SolidSwitch (thus, stopping the alternator).
Is this right?
Thanks in advance!
cerbo gxRelayalternator
