affordablemarine avatar image
affordablemarine asked
How to connect Multiplus, (3) BlueSolar and SmartShunt to Cerbo GX
I have a Multiplus 12/3000/120-50, (3) bluesolar charge controllers, (1) SmartShunt and connecting it to a Cerbo GX. The Cerbo has only (3) VE direct connections that will connect to the Cerbo GX. How do I connect the SmartShunt to the Cerbo GX. The SmartShunt has a VE direct communication port only.
MPPT Controllerscerbo gxSmartShuntmultiplus ve.bus
With the VE.Direct to USB cable.
https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
You can also use an USB hub.
We already had that question a few times.
snoobler avatar image snoobler commented ·
Please confirm. In this case, user would need:
3X VE.Direct to USB cables
2X VE.Direct cables
USB hub
Blue Solar 1: VE.Direct to Cerbo.
Blue Solar 2: VE.Direct to Cerbo.
Cerbo VE.Direct to USB to hub.
Blue Solar 3: VE.Direct to USB to hub
SmartShunt: VE.Direct to USB to hub
Matthias Lange - DE avatar image Matthias Lange - DE ♦ snoobler commented ·
The USB hub goes into a USB port of the Cerbo.
3 devices can be connected directly via VE.direct and 2 via VE.direct to USB. If you have more than 5 devices you need an USB hub.
snoobler avatar image snoobler Matthias Lange - DE ♦ commented ·
Thanks! I forget about the USB port!
