antonio-gioioso avatar image
antonio-gioioso asked
DC/DC converter to battery
Hi, i'm developing a full electric propulsion plant for an e-boat (scheme in the image attached).
I have a doubt: i'm gonna use a 12V service battery to power on board hotels, feeding the service battery with current with voltage scaled by the DC/DC converter (the Victron Energy Orion Tr-48/12-9, as you can see in the scheme). The problem is that the DC/DC converter could continue to feed the battery even when the battery is fully charged, leading to overcharge and its dangerous consequences. How could i solve this problem?
batteryvictron productsdc system
Alexandra avatar image
Alexandra answered ·
@Antonio Gioioso
See the question I had a while ago.
That being said you could always set up a bmv and use the relay to switch the orion on or off with the remote terminal.
But they dont keep pushing 9A out if there is no load to use it
antonio-gioioso avatar image antonio-gioioso commented ·
Thanks Alexandra
