Todor Neshev avatar image
Todor Neshev asked
Victron Multiplus remote switch battery on / off
Is there an option to send signal like 3.3 volt to Victron Multi so it stops inverting like stop using batteries. I do not want to use SOC/DOD or voltage values. Just send remote signal via other device and force victron to stop inverting and use normal AC grid. Then later when i remove 3.3 volt to start using again the batteries. Actually i need only inverting from victron and ups function.
batteryvictron productsmultipus
Alexandra avatar image
Alexandra answered ·
@Todor Neshev
Not really what you were looking for, but a contactor and relay that can be signalled disconnect and connect the main grid would be easier to set up.
The other option is to use the GX device and navigate it that way.
