adco avatar image
adco asked
Grid feed disabled but i still see feed values in VRM
I have 2x EasySolars 24/3000 (basicaly Multipluses) configured in parallel.
Probles is I have disabled Grid Feed In from ESS but in the VRM i still see e.g. -90w (oscilates up to even -300w when heavi load).
What am I missing? I do not want to feed in and I know that small W is ok but not that high.
Any ideeas?
ESSVRMmultiplus in parallel
Paul B avatar image
Paul B answered ·
raise the grid set point to say 100w or as low as you can get to reduce the feed in issue.
I never see a feed in when I have a small positive grit set point set.
I am on the latest fw for all items cerbo 2.85 multi 496
adco avatar image adco commented ·
Thanks Paul!
Seems that rising to 100w works. I had it with 0 and 50w but as you mentioned with 100w now I see just pozitive values no more negative.
Thanks again!
