ngraetz avatar image
ngraetz asked
VE.Bus Smart Dongle with Multi Plus 12/3000/120 Inverter Charger
Hi, I was wondering if someone has an answer. When I look at the Smart Dongle connected to my inverter on the Apps first Screen I get a message "AES - Load below threshold" and the Battery reads 13.85V -0.7A 85% 22C.
On the 2nd Screen under "State" I get the same message. It also says "Grid disconnect reason" - "L1 AC input disconnected" and shows for this reason under AC input L1all Zeros. Under AC Output it shows Voltage 75, Current 0.05A, Power 2 W, Frequency 60.1 Hz. Nothing was connected to the outlets.
Does anyone know what is wrong and what AES load below threshold means?
multiplus ve.busVE.Bus Smart Dongle
