laimena avatar image
laimena asked
Cerbo GX on VRM
Hello, i just bought a Cerbo GX and trying to connect with VRM, it is said request access. need approval from administrator. i'm lost. i tried to contact the Seller, seller don't have knowledge. tried to contact Area Manager, he gave me distributor contact. tried to email the distributor but no luck. i need to setting ESS on my Multiplus II 48/3000. can't do that without VRM remote access. thank you
my running firmware is 2.84.
cerbo gxVRM
nickdb avatar image
nickdb answered ·
The seller should have deleted the cerbo from their setup first.
laimena avatar image laimena commented ·
but the seller claimed they have no knowledge. thank you. is there any way to over ride it?
nickdb avatar image nickdb ♦♦ laimena commented ·
Not without Victron's help, they will usually insist you manage this via the distributor.
@Guy Stewart (Victron Community Manager) are you able to assist here?
laimena avatar image laimena nickdb ♦♦ commented ·
i tried to contact the distributor in Canada as per Area Manager Carsten Michelsen gave me their email. but no reply from the distributor. @Guy Stewart (Victron Community Manager) please assist me. i do have the purchase invoice
laimena answered ·
ok, just now seller contact me and i already can add the Cerbo GX device. thank you @nickdb for your fast reply and kind assistant
vir avatar image
vir answered ·
if the seller deletes the cerbo from their setup, will the configuration in the cerbo remain the same?
i have the same issue currently with the VRM message above. I am the first owner.
otherwise, if the seller gives me admin rights that i can access from my own VRM portal, can i then remove the seller admin from my device? thanks
