22-03-03 13-54-33 6387.jpg22-03-13 23-07-33 6413.pngHi
I wonder why my RS450/200 is stuck at 100 Amps. What do I need to configure that all trackers deliver its max? I can not adjust this setting in the pics. What am I missing here?
Thank you
Thank you
Hi @ppr
If you can't raise that 100A setting as suggested, maybe check your firmware. This shouldn't happen of course, but who knows..
VictronProfessional lists both model's firmware separately..
If you attempt a firmware update via Device List in VRM, the 'A111' Product Id should show as current.
I reinstalled the Firmwrae 1.08
sadly no change.
Strange is, should Bootloader not be as well 1.08 ??????
There is an issue in VictronConnect that makes 100A the max settable value by the user. What you can do is reset settings to factory defaults:
Connect to the MPPT -> Go to settings -> Press the three dots icon at top right corner -> Reset factory defaults. Then configure all the settings but do not change the max current value, it will remain 200A.
We are going to make a VictronConnect release soon including a fix for this issue.
It was not only the Factroy default. When I changed it to factory default, it kept the setting for a few seconds and reseted it automatically to 100A again.
I had to adjust and redo the Battery config, after that part, it kept the setting at 200A
48 People are following this question.
