rrroonn avatar image
rrroonn asked
Help with strange Color Controller behaviour with MP2 and SMA
Hi, I have the following configuration:
  • Victron MP2 5000 / 70amp charger
  • SMA 5000TL-21 solar inverter on AC-Out#1
  • Pylontech US3000 batteries
  • Color Controller
If I have to turn the SMA inverter off and then turn it back on later, the CC display looks like this (still) after 15 minutes from turning on the SMA Inverter:
You can see that the Solar inverter is working because it is exporting, however:
  • SMA inverter is not shown,
  • AC Loads are not registering (=0) despite being around 600W.
The SMA is remembered:
But does not appear on the device list:
This has happened a few times and it often takes hours before the display corrects itself.
I was running FW 2.51 on the CC but saw that 2.52 was available, so I installed that, but alas, still the same problem.
The CC and SMA are both on the same subnet and I can confirm that the SMA has obtained its IP address which is fixed by DHCP settings. I can confirm this by the SMA front panel.
Is this a known issue?
thanks for your assistance,
Ron
Multiplus-IIVenus OSsolar
rrroonn answered ยท
Looks like it is an issue with the SMA modbus server.
I had the issue occur again, so I tried another modbus client and it would not connect. I used Sunny Explorer to change the modbus port on SMA and then could connect, then changed it back. CC then connected ok.
Rob Fijn avatar image
Rob Fijn answered ยท
Helllo, @rrroonn, could this help:
https://www.victronenergy.com/live/ccgx:ccgx_sma
best regards,
Rob
rrroonn avatar image rrroonn commented ยท
Thanks Rob, have seen that.
I spent some time originally before the Victron was installed making sure the MODBUS was working as I had to retrofit the speedwire module.
As I mentioned, its not that the CC doesn't eventually see the SMA and start working correctly, its just that it takes such a looooong time to do so. As per the event I highlighted yesterday, an hour after the post, the CC started showing the correct information.
Maybe I just need to raise it as a software fault?
Ron
0 Likes 0 ยท
