Elimac avatar image
Elimac asked
How to have Smartshunt mid point voltage measure and Temperature at same time?
In some offgrid installations, using 150V Smartsolar MPPTs, I need to have both temperature compensation and mid point voltage measuring in a 48V battery bank. Additionally, being a remote site, it will have a CerboGX and a Smartshunt.
I was assuming I could use the AUX port of smartshunt to have the mid point measuring and the temperature sensor input on the CerboGX to have the temperature. But in a recent test, I got doubts because in a VenusGX I have for tests I couldn't select the Temperature Sensor in DVCC.
So, I ask the forum, can this be achieved?
cerbo gxVenus OSSmartShuntTemperature Sensor
Elimac avatar image Elimac commented ·
I'm aware the temperature sensors must be different models, depending if connect to Smartshunt or GX device. I'm using the correct models.
Elimac avatar image
Elimac answered ·
I think this works:
In Venus OS, one must select the right type of GX Sensor (ASS000001000) setup page:
If use Generic, it won't show in DVCC. But used as Battery Sensor, we will be able to use it in DVCC. Anyone can confirm this is ok?
Hi @Elimac,
yes, if you chose Battery as the type of the temperature sensor, it will appear in the DVCC menu, where you can select it as temperature sensor for the battery.
