Hi my victron blue charger ip65 12/7a in storage mode is showing current of 3amp at 13.20v no other car or victron blue charger is showing any current in storage mode
How are you measuring the current?
But sounds as if it's a faulty unit.
Hi @MATTD,
This is normal behavior when loads are active as the loads are then powered by the charger. If there is more than one charger in the system, one will take precedence over the others due to different resistances and wiring.
But that's all guessing because we don't know how your system is built and what components are included. Please provide us with a system diagram and maybe images of your system.
Hi I may be I'm the wrong community this is a ip65 12v 7amp car charger with a single car battery in a holden V8 1996 VS calais I have other cars almost the same and none have 3amps on storage so the system is using power somehow.
Has the charger been connected more than 24 hours and this continues (3 A charging)?
Do you have the possibility to measure the output from the battery, maybe through a clamp meter (for DC measuring)?
32 People are following this question.
