tomf avatar image
tomf asked
Update firmware MultiPlus - leds blinking - 2606xxx
I have old Multi Plus Compact 12/1600/70 with 2606154.VFD
I would like to connect them with BE.Bus smart dongle.
And set couple variables like:
Max charge into 30Ah etc...
Set search mode ... etc...
After first connect via USB-mk3 I received info that firstly I should to upgrade firmware.
"Current firmware version is v 154 and is not compatible with Victron Connect..... install 415".
So I download firmware:
2606494.vff and install it.
But after that I have battery status "fault" info and LED start blinking ((green yellow) : (reed)).
So I checked with:
2606433.vff
2606209.vff
and stopped at:
2606159.vff - where Multi starts runing.
What to do with that?
It means that I will not allow to use Victron Connect to set params? Mk3 is useful in this case and VE.Bus Dongle too...
Tom
MultiPlus Quattro Inverter ChargerVictronConnectVE.BusVE.Bus Smart Dongle
JohnC avatar image
JohnC answered ·
Hi @TomF
Try it with VEFlash.. https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
Also, and for either way, don't confuse the VE.Bus by having something else (eg smart dongle or GX link) connected. Use the MK3 alone into the Multi.
tomf avatar image
tomf answered ·
1. @JohnC I used MK3 alone.
2. Upgrading via MK3 is finalized in my opinion. If I could switched between firmware version.
I could install different version and rollback.
But I see that after upgrade over xxxx200 version I have battery status fault and blinking leds.
Inverted and charger is off.
Hmm I was thinking that it could be because I would like to set Multi at home with small 60Ah battery, and then connect into right one.
Using VEFlash is really painfull because I have MacOS system. I inastall windows there and even bought adapter USB -> USB-C. But at the end VE.Flash do not see connection.
tomf avatar image
tomf answered ·
Ok, I have to use VE.Flash on windows and MK3, I also have to upgrade drivers for VE.Bus (no option with mac). Now working fine.
