tedr avatar image
tedr asked
change ET112 meter from L1 to L2 (or L3)
Just a cosmetic problem.
In the Cerbo GX the PV-inverters connected to phase L2 and L3 are displayed as L1.
this gives a wrong calculation of the AC Loads.
PV-Zuid is connected to L3.
Is there a solution to tell the Cerbo GX that the ET112 is connected to an other phase than L1?
Thanks,
Ted
cerbo gxEnergy Meter
patricknl avatar image
patricknl answered ·
I have the same Issue with my ET112. I hope Victron is working on a solution, as far as I can tell it's a mere calculation/ missing setting issue.
Additional: For now I have placed my AC-Coupled PV inverter on L1 instead of L3 to have the right numbers in the dashboard. L1 is quite a bit more crowded with PV installations than L3 sadly..
gesiima avatar image
gesiima answered ·
Need a better sollution for that problem too.
