federico993 avatar image
federico993 asked
67 "BMS connection lost" on the 100/20 MPPT with REC BMS
Hi, my system consists of a REC ABMS connected to the Raspberry running Victron Venus 2.60, through CAN bus, a BMV 712, a Multiplus Compact 2000VA and a 100/20 MPPT controller.
Everything seems to work fine, but I get this 67 error BMS connection lost randomly that turns off the controller and I need to reboot the Venus OS from Settings -> General to make it work again.
Does anyone know what to check?
Thank you!
MPPT ControllersBMSerrorVE.Can
