midsummerenergy avatar image
midsummerenergy asked
Quattro Micro-Grid with External Islanding
A Grid-tied Quattro set up as ESS with Fronius PV inverter (Country Code set to 'Other - Not Compliant') on Output using Frequency Shifting. Quattro cannot be installed at grid connection point so cannot use built-in anti-islanding. Loads connected on AC Input and AC Output side of Quattro. Grid connection point is fitted with external anti-islanding relay.
When operating stand-alone as a Micro-Grid - the external anti-islanding relay isolates the grid supply - so there is no external voltage at AC Input, will the Quattro allow and regulate PV power to the AC Input as well as the AC Output?
FroniusRelayfrequency
stevo07 avatar image
stevo07 answered ·
The Quattro can only use frequency shifting on its output, not the input.
midsummerenergy avatar image midsummerenergy commented ·
Thanks for clarifying.
