mday73 avatar image
mday73 asked
CERBO GX USB 2.0 or 3.0?
I am having to expand the number of USB inputs to my CERBO GX by adding a powered hub. Does Victron recommend the use of USB standard 2.0, 3.0 Gen 1, or 3.0 Gen 2?
Many thanks.
VictronConnect
The Cerbo has USB 2.0 ports so it would not make sense to use an USB 3 Hub.
downunder avatar image
downunder answered ·
Why not. USB 3.0 is backwards compatible—meaning it's designed to work with older USB versions including USB 2.0 and USB 1.1. Some of the USB 3.0 powered hubs are even cheaper than the 2.0 ones.
louvre-01 avatar image
louvre-01 answered ·
Hallo,
wie Matthias schon sagte, nehme einen USB2 Hub.
Ich habe es bei meiner Anlage selbst ausprobiert, ein USB3 Hub funktionierte bei mir nicht zuverlässig
mike4nl avatar image
mike4nl answered ·
